Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 and Aries Ethernet PowerLink I/O
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
The Compax3 I30-T11 has 8 inputs, 4 outputs and are PNP. NPN is possible but needs a pull-down resistor (see user manual or C3 ServoManager's online help).
The Aries-EPL has 7inputs and 4outputs, and can be wired NPN or PNP.
