Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Sample code for PACIO-442-02 and PACIO-441-02 analog modules
Example of setting an analog output module PACIO-442-02 and analog input module PACIO-441-02
Note:  Analog output module requires 24volts connected at the bottom. Analog input module does not. If you connect pins0 together between the 2 modules and then also pins1 together on the 2 modules, the voltage will continuously cycle from 0 to 10volts
Select the project that matches your version of Parker Automation Manager:
PAM1.4: Simple_Gearing_to_PACIO454_Encoder_PAM1.4
PAM1.2: Simple_Gearing_to_PACIO454_Encoder_PAM1.2
1NOV18 - JD - update
  • analog
  • PACIO
  • modules
  • 442
  • 441
  • sample
