Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Do I have to upgrade my PAC 1.3.0 Firmware to work with a PAM 1.4.0 project?
Users using PAM 1.4.0.1077 projects must download to a PAC running 1.4.0.1077 rev firmware. Likewise, users using PAM 1.3.0 projects must download to a PAC running 1.3.0 firmware.
Any PAM 1.3.0 projects can be updated to a 1.4.0.1077 project when opening them in PAM 1.4.0.1077. Once updated, the project will then have to be downloaded to a PAC running 1.4.0.1077 firmware.
If a user opens a 1.3.0 .projectarchive in PAM 1.4.0.1077 and chooses not to update they must ensure that they’re downloading the project to a PAC running 1.3.0 firmware.
