Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Does PAC act as a OPC-UA server or client, or both?
As of Parker Automation Manager and Firmware Rev 1.4.0.1077 the PAC is only capable of running as an OPC-UA Server.
