Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I upgrade the PAC from OPC-DA to OPC-UA?
OPC-DA comes as a standard, default communication available on all PAC models.
OPC-UA is handled as a hardware license, meaning to upgrade from OPC-DA to OPC-UA the PAC must be returned to the factory under an RMA to be upgraded.
