Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Software - How to completely clear (factory default) the Compax3
To reset the Compax3, enter the following command in the optimization input window:
:erasecfg
If the unit is a T30 or T40 this will also clear the IEC program.
This will competely erase the drive's configuration and reset the Compax3 to factory default settings as if the unit had just been shipped.
