Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Which HMI runs Interact?
    • Interact (Legacy)-
      • CTC and i-Motors
      • TCP/IP open port failure
      • HMI Battery Replacements
      • INTERACT How to Order
      • Which HMI runs Interact?
    • Interact Xpress+
    • IX / PCA+
This is a follow-on list with more detailed part number information for Interact HMIs (MSDOS/ROMDOS) for the FAQ with HMI Grid
What software runs on my hardware Grid
(Click on image to expand)
edited dom 02/13/2019
  • P7
  • P3
  • INTERACT
  • PS
  • P8
  • PA
  • P6
  • MSDOS
  • P1
  • P2
  • HPC
  • IPC
  • P4
  • PWR
  • PA2
  • P9
  • P5
