Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Misc - Which HMI runs Interact Xpress?
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
This is a follow-on list with more detailed part number information for Interact Xpress HMIs (WinCE Based runtime, Windows Development) for the FAQ with HMI Grid
What software runs on my hardware Grid
(Click on image to expand)
edited dom 02/13/2019
  • Xpress
  • XPR
  • XT
  • XPR2
