Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Smart Encoder Compatibility
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Smart Encoder Compatibility
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
The Smart Encoder option (Q) for the MPP/MPJ (order code 3E), SM/SE, BE, NeoMetric/J series motors were only designed to work with the Aries drive. The Smart Encoder uses the Hall output lines as means of communication with the drive to tell it all the pertinent motor settings. This means that the Hall outputs of the Smart Encoder are not used in the traditional fashion and therefore not compatible with any other drives*.
Note: The transfer of motor settings from the Smart Encoder to the Aries drive takes about 3 seconds every time the drive powers up.
*The Compax3 F12 can be made to work by using hall-less startup (wake & wiggle) to ignore the hall sensor feedback. For the Compax3 F12, the feedback cable would need to be changed to the F-2C1.  A custom motor file will need to be created using the Compax3 Motor Manager software. Here's a link to the videos that step you through this. On the last screen of the Motor Manager, change the standard motor file under Commutation: Digital hall sensor  to Automatic commutation with movement.
Note the video shows Commutation angle for a resolver motor but for an encoder it'd be a pull-down selection:
https://community.parker.com/technologies/electromechanical-group/w/electromechanical-knowledge-base/1236/video-how-to-create-custom-rotary-motor-file-for-compax3
This is shown in the 3rd video of that series at this point in the video:
https://youtu.be/zVkKVGBBrQU?t=349
Note: The newer Pseries cannot be used with hall-less commutation with the Smart Encoder feedback without modifying the F-4A1 cable:
https://community.parker.com/technologies/electromechanical-group/w/electromechanical-knowledge-base/2226/hall-less-commutation-with-the-p-drive
Motors can be converted to standard incremental encoder via a repair RMA. Contact your ATC distributor for price quote.
