Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PAC with Turck Modular I/O System
      • 3rd Party Samples-
        • PAC with Baumer vision inspection
        • PAC with Cognex Camera
        • PAC with Turck Modular I/O System
        • PAC with Wago EtherCAT IO
The documents below cover how to setup and use Modbus communication between the Parker Automation Controller and a Turck Modular Series Ethernet Gateway. The link below provides access to the instructions, an example program written in PAM and the related manuals for the hardware required.
Download Link
  • PAC
  • Turck
  • IO
  • modular
  • I/O
