Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base eCL Homing notes with PAC via EtherCAT
Use SMC3_ETC_WriteParameter_CoE to do a SDO (acyclic 'one-shot' data write) to the eCL to set the Homing Speed and Homing Mode before doing an MC_Home.
Index and subindex are listed in eCL user manual.
eCL_PAC.txt
PROGRAM PLC_PRG
VAR
	YPower: mc_power;
	bTurnOnY: BOOL;
	Ymove: SM3_Basic.MC_MoveRelative;
	bMoveY: BOOL;
	Yhome: SM3_Basic.MC_Home;
	bHomeY: BOOL;
	YSetHomingMode:SM3_Drive_ETC.SMC3_ETC_WriteParameter_CoE;
    bYSetHomingMode:BOOL;
	YSetHomingSpeed:SM3_Drive_ETC.SMC3_ETC_WriteParameter_CoE;
    bYSetHomingSpeed:BOOL;
END_VAR
YPower(
	Axis:= Y,
	Enable:=	TRUE,
	bRegulatorOn:= bTurnOnY,
	bDriveStart:= bTurnOnY,
	Status=> ,
	bRegulatorRealState=> ,
	bDriveStartRealState=> ,
	Busy=> ,
	Error=> ,
	ErrorID=> );
	Ymove(
	Axis:= Y,
	Execute:=bMoveY ,
	Distance:= 1,
	Velocity:= 1,
	Acceleration:=10 ,
	Deceleration:=10 ,
	Jerk:= ,
	Done=> ,
	Busy=> ,
	CommandAborted=> ,
	Error=> ,
	ErrorID=> );
YSetHomingMode(
	xExecute:=bYSetHomingMode,
	xAbort:= ,
	uiIndex:=16#6098 ,
	usiSubIndex:= 0,
	usiDataLength:=1 ,
	dwValue:= 1,
	Axis:= Y,
	xDone=> ,
	xBusy=> ,
	xError=> ,
	dwErrorCode=> ,
	eError=> );
YSetHomingSpeed(
	xExecute:=bYSetHomingSpeed,
	xAbort:= ,
	uiIndex:=16#6099 ,
	usiSubIndex:= 1,
	usiDataLength:=4 ,
	dwValue:= 10000,
	Axis:= Y,
	xDone=> ,
	xBusy=> ,
	xError=> ,
	dwErrorCode=> ,
	eError=> );
Yhome(
	Axis:=Y ,
	Execute:= bHomeY,
	Position:= 0,
	Done=> ,
	Busy=> ,
	CommandAborted=> ,
	Error=> ,
	ErrorID=> );
ECLD-4DC-PC  EtherCAT Stepper drive wiring for Limit Sensors (Limit+, Limit-, Origin; and Inputs & Outputs)
aka End of Travel and Home inputs
NPN sensors required with wiring shown.
