Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Motors - Speed/Torque Curves 120/240vac (PM-Fxx)
Pseries_SpeedTorque.pdf
Dashed line is the motor's continuous torque.
Solid line is motor's peak torque.
