Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Misc - Connecting an ACM2n Motor
Connecting AC M2n Motor to a Compax3 Drive
Since Parker does not supply cables for this combination, below is PDF for wiring a AC M2n motor to Compax3 drive.
ACM2N_Compax3.pdf
  • AC M2n
  • Compax3
