Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Troubleshooting - Xpress Manager Menus clipped/chopped off. Setting size to Small/Medium/Large does not change the viewable menu.
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
The development environment is effected by the Windows Preferences settings. Changing the size settings in Xpress Small/Medium/Large just magnifies the visible screens and has no effect on the sizing of the menus and text.
The newer PCs/Laptops have very high resolution displays. To make icons and text more readable on the desktop and in Microsoft programs like Office, there is a setting in the Desktop Preferences to scale up the text.
Right click on the Windows Desktop and select Personalize.
Click on Display
Set the scale to 100% - Anything larger causes the truncating of the viewable menu.
dom 02/20/2019
  • Truncated
  • Xpress
  • Clipped
  • DEVELOPMENT
  • Menu
