Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Dynaserv Flying Lead Cable
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
The part number for the flying lead cable already setup in our system is:
CP*71-025452-10
It's a 10-foot cable Dynaserv Honda connector to flying lead cable.
It's the same as the C1P-ENN-4202 cable listed in the manual.
For older Gen1 Dynaserv drives that have the 50pin Honda connector, the part number for a 6000 to Dynaserv 50pin Honda Cable that has the servo command signal wires and encoder feedback with flying leads on the controller end is: 71-014536-10
