Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Can I clone an 890 drive via the Keypad?
    • AC890 Series-
No you can not clone an 890 via a keypad. In order to 'clone' a new 890 drive you must use DSELite or DSE890 and upload the configuration in a general extract/install procedure.
  • Potentially, you may need to run an additional autotune on the new 890 drive to ensure proper functionality after installing the configuration.
See this FAQ for extracting and installing configurations: How to install/extract parameters for an 890
12APR19 JD
  • cloning
  • keypad
  • clone
  • 890
