Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base AC-03 / AC-07 / AC-10 / AC-15 manuals
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
NOTE: Parker offers and has offered many products with similar names.  The AC-10 and AC-15 mentioned here are not the same as the AC10 and AC15 induction motor drives.  For more information on those products, go to parker.com and use the product search tool.
The MTS drives known as the AC-03, AC-07, AC-10, and AC-15 are rack-mounted, modular servo drives part of the MAS systems.
They are powered by the PS015, PS030, and PS060 modular power supplies.
The user guide is available on our website, under Literature --> User Guides -->
Custom Servo Motors --> Manuals Download, but instead of being called AC drives, they are referred to as MTS Multi-Axis systems. You can also get the user guide here.
These drives and rack systems are no longer available.  System upgrade is really recommended as there will not be easy drop-in amplifiers for that rack-mounted topology.  New applications should instead use the Compax3 series of amplifiers and the Compax3 may make sense for the system upgrade as well depending on how many axes and the sizes of the motors in use.  Contact your local ATC (distributor) for help in assessing upgrade/replacement options.
MAS  AC-07 AC-03 AC-10 AC-15
Updated 02NOV2021 DCLIFFE -- Clarified products described in this article.
