Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPM Motors - MPM Number of Motor Poles
Below is a chart showing the number of poles for the MPM series brushless servo motors.
MOTOR MODEL NUMBER NUMBER OF MOTOR POLES
MPM40 4
MPM66
MPM72 6
MPM89
MPM114
MPM190
MPM320 12
