Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gearhead Customization - Gearhead output shaft diameter modifications
  • Gearheads-
The output shaft dimensions can relatively easily be modified to suit your needs. However, there are manufacturing limitations to the range of dimensions that Parker can feasibly build to. Below is  a chart of the standard and maximum dimensions that are available to each family and frame size.
Note:
  • The PV is not included since we cannot customize that family.
  • Right angle gearheads use the same output dimensions as their respective inline version. In other words, RS applies anywhere you see PS, and RX applies anywhere you see PX.
  • Turning the shaft smaller than the standard diameter listed below may potentially decrease torque capability.
Diameter Length
Standard Maximum Standard Maximum
PX60
16
18
25
53
PS60
16
18
40 84
PX90
20
27
40
81
PS90
22
30
52
118
PX115
24
34
50
100
PS115
32
38
68
137
PS142
40
50
102
180
