Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base General - Industrial servo motor output shaft diameter modifications
The output shaft dimensions can relatively easily be modified to suit your needs. However, there are manufacturing limitations to the range of dimensions that Parker can feasibly build to. Below is a chart of the standard dimensions for each family and frame size. The diameter can relatively easily be turned down, but larger diameters are significantly more difficult and typically require heavy customizations. Note that turning the shaft smaller than the standard diameter listed below may potentially decrease torque capability.
Diameter Length
SM16 6.35 24.8
SM230 6.35 19.8
SM231
SM232
SM233
9.53 20.8
BE16 6.35 24.8
BE23 9.53 31.9
BE34 12.7 30.3
MPP092 16 40
MPP100 19 40
MPP115 24 50
MPP142 28 60
MPP190 38 80
MPP270 48 110
