Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base ACR7000 and IPA - AcroBasic PROGRAM SAMPLES
      • 7000-
        • ACR Binary Host Interface - 7000 and IPA
        • ACR7000 and IPA - AcroBasic PROGRAM SAMPLES
        • ACR7000 Connector part numbers
        • ACR7000 Controller differences to ACR9000
        • ACR74T Stepper Power Supply Sizing
        • ACR74V ACR78V: How to Reset BiSS Absolute Encoder Position
        • BE and SM Servo Motor Speed-Torque Curves at 24volts and 48volts
        • Expanded DEFINES allows numeric characters
        • Expansion I/O Information for ACR7000 and IPA
        • P Series Servo Motor Speed-Torque Curves at 24volts and 48volts
        • Parker Motion Manager Software Computer Requirements (32bit vs 64bit)
        • Parker Motion Manager: What's New or Different Compared to ACR-View?
        • PC to ACR Program Samples (Excel, LabView, VB.Net, C++, C#)
        • Stepper Motor and Feedback Connectors
        • Time Saving Tip: Use Axis Copy if using same motor on other axes
        • Using #DEFINE inside PMM programs
      • 9000 (Legacy)+
Below AcroBasic samples can be inserted into Parker Motion Manager's Program Editor. Samples are commented explaining the code. Note the Program Editor in PMM color codes making it a bit easier to read.
Users learning AcroBasic should start with the new ACR Programmer's Guide click here. It explains programming AcroBasic and Parker Motion Manager software.
Single axis:
1axis_BasicMotion.txt
1axis_CAM.txt
1axis_Enable_sub.txt
1axis_Error_Recovery.txt
1axis_Homing_sub.txt
Two axis:
2axis_BasicMotion.txt
2axis_CAM.txt
2axis_Enable_sub.txt
2axis_Error_Recovery.txt
2axis_Gearing_for_Servos.txt
2axis_Joystick_EthernetIP.txt    or   2axis_Joystick_EthernetIP_ACR74T.pprj (use PMM version 2.0 or 2.1)
Three axis:
3axis_BasicMotion.txt
3axis_Enable_sub.txt
3axis_Error_Recovery.txt
3axis_Homing_sub.txt
Four axis:
4axis_BasicMotion.txt
4axis_Enable_sub.txt
4axis_Error_Recovery.txt
4axis_Homing_sub.txt
General examples:
Generic_Structure.txt       General example for structure for an AcroBasic program.
CaptureData.txt                Program to setup multi-channel high-speed data capture.
EIP_Peer-to-Peer.txt        Program to exchange variables between 2 ACR7000's via Ethernet/IP.
EIP_Scanner.txt               Program to configure ACR 7000 as ENIP master for Wago 750 series expansion IO.
Stepper_HomeHardstop.txt      Sample on how to use an encoder based step motor home to a hard-stop.
Stepper_PrintMotorSettings.txt     Sample on reading the motor settings for stepper ACR 7000 from terminal window in PMM.
Stepper_Settings.txt                 Sample showing storing motor settings within an AcroBasic program (optional).
Stepper_Statusreport.txt           Sample showing viewing current status of stepper ACR 7000 from terminal window in PMM.
Servo_HomeHardstop.txt         Sample on how to home to hard-stop with a servo motor with a torque limited move.
OpenPort_7000_IPA.txt            Sample for opening a port for external device to send Ethernet TCP/IP comms to ACR7000 or IPA, using INKEY, STRING data
Time.txt                                     Sample using Defines and variable math with LRUN in terminal window to see how long a controller has been running.
Xpress + ACR7000 Jog Teach  Sample Xpress HMI project for showing connecting/running ACR7000 from touchscreen. 2axis jog and teach panels.
Xpress + IPA Jog Teach            Sample Xpress HMI project for showing connecting/running IPA from touchscreen. 1axis jog and teach panels.
Misc examples:
DetermineController.txt          Sample IF statement using system parameters unique to 7000 servo/stepper/controller and IPA to determine controller type
PC to ACR Samples               Knowledgebase Post with Samples for Excel, LabView, .Net (C#, C++ and VB)
IPA AOI's v5.1 (PMM)             IPA's Add On Instructions for use with AB Control Logix or Compact Logix PLCs
                                                     IPA Ethernet/IP User Guide   Video Demo
ACR7000 Stepper:     http://www.parkermotion.com/products/Stepper_Drive_Controllers____30_32_80_567_29.html
ACR7000 Servo:        http://www.parkermotion.com/products/Servo_Drive_Controllers__7329__30_32_80_567_29.html
ACR7000 Controller:  https://www.parkermotion.com/products/Controllers__7329__30_32_80_567_29.html
  • parts@benchmark-imaging.com
    parts@benchmark-imaging.com 1 month ago
    The link to "2axis_Joystick_EthernetIP_ACR74T.pprj" is broken.  Does anyone have a working link to this project?
    • Vote Up 0 Vote Down
