Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Aries Resolver Replacement (AR-01AR, AR-02AR, AR-04AR, AR-08AR, AR-13AR, AR-01SR, AR-02SR, AR-04SR, AR-08SR, AR-13SR)
    • Aries Drive (Discontinued)-
      • Controller (CE)+
      • Drive only (AE,AR, SE, SR)+
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
This resolver option on the base Aries servo amplifier was obsoleted in 2014.
This was only offered as an option on 1300watt sizes and smaller and only on the A analog or S step & direction base servo amplifiers.
Typically, resolvers are used in applications that have a harsh industrial environment containing some excess of dust or vibration, for example. One thing to consider is that standard encoders manufactured today are not as fragile as their past counterparts and may well be acceptable in a customer’s application. In applications that absolutely require a resolver option on a drive, we would recommend a comparable Compax3.
Aries Resolver Aries Encoder Aries Encoder cable for PS connectors Compax3 Resolver Compax3 Resolver with Ethernet Compax3 Resolver cable for PS connectors
AR-01AR AR-01AE F-1A1-XX S025V2F10I10T10M00 S025V2F10I30T11M00 F-2B1-XX
AR-02AR AR-02AE F-1A1-XX S025V2F10I10T10M00 S025V2F10I30T11M00 F-2B1-XX
AR-04AR AR-04AE F-1A1-XX S063V2F10I10T10M00 S063V2F10I30T11M00 F-2B1-XX
AR-08AR AR-08AE F-1A1-XX S063V2F10I10T10M00 S063V2F10I30T11M00 F-2B1-XX
AR-13AR AR-13AE F-1A1-XX S063V2F10I10T10M00 S063V2F10I30T11M00 F-2B1-XX
AR-01SR AR-01SE F-1A1-XX S025V2F10I10T10M00 S025V2F10I30T11M00 F-2B1-XX
AR-02SR AR-02SE F-1A1-XX S025V2F10I10T10M00 S025V2F10I30T11M00 F-2B1-XX
AR-04SR AR-04SE F-1A1-XX S063V2F10I10T10M00 S063V2F10I30T11M00 F-2B1-XX
AR-08SR AR-08SE F-1A1-XX S063V2F10I10T10M00 S063V2F10I30T11M00 F-2B1-XX
AR-13SR AR-13SE F-1A1-XX S063V2F10I10T10M00 S063V2F10I30T11M00 F-2B1-XX
Note for the Aries encoder would need to have a new motor with an encoder.
Note for the Compax3, the connectors are different and the cable connecting the controller will need to be updated. If using a Parker controller, see this post for controller to drive cables:
https://community.parker.com/technologies/electromechanical-group/w/electromechanical-knowledge-base/1139/controller-cable-drawings
The motor cable does not need to be changed.
Presumes standard static cables. High-flex cables available (FH-1A1-XX or FH-2B1-XX).
Parker EMN Servo Drives:
http://www.parkermotion.com/products/Servo_Drives____30_32_80_567_29.html
