Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base GFB-KIT Pinout
GFB-KIT Pinout
Attached is the user documentation for the GFB-KIT, p/n 88-018701 for the user document.
The connector does have the numbers printed on them but because they are quite small and difficult to read, attached is the 3M literature that shows the pinout.
GFB-KIT Pinout
