Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base VB generates Runtime Error 91 (accessing through the ACR Comm Server)
        • Axis Flag update rate
        • Encoder Velocity
        • Evaluation Underflow error
        • How to receive ASCII data
        • INTCAP
        • Reboot in startup program
        • Use of AXIS format
        • User Variables
        • Using Encoder 8 or 9 as SRC
        • What is the axis velocity
      • 9000 (Legacy)+
Error: "Runtime Error 91" is a Visual BASIC error which means "Object variable not set". This indicates that the object was never created using the "Set" command before being used.
Remedy: Be sure to use the SET statement to create the new oject.
Example: (also shows Ethernet connection)
Dim stat As BOXBRIDGELib.Status
Dim util As BOXBRIDGELib.Utility
Dim cntl As BOXBRIDGELib.Control
Set stat = New Status
stat.bOnConnectTest = False
stat.bstrIP = "192.168.10.40"
stat.Connect 3, 0
Set util = New BOXBRIDGELib.Utility
util.bOnConnectTest = False
util.bstrIP = "192.168.10.40"
util.Connect 3, 0
Set cntl = New BOXBRIDGELib.Control
cntl.bOnConnectTest = False
cntl.bstrIP = "192.168.10.40"
cntl.Connect 3, 0
