Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Error 17000 when attempting to communicate to ACR
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
This is caused by an incorrect version of the ComACRsrvr.DLL file being used with the executable program.
This is commonly seen when using a Visual C++, Visual Basic, or .NET application that was compiled using an older (or possibly) newer version of the ComACRsrvr.DLL file.
To resolve the error, compile the project using the required version of the DLL.
