Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How to use the In Motion Bit
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
The In Motion bit goes high anytime the master is commanding motion. Each master has an In Motion bit, which can be found in the Master Flags, Primary Master Flags.
Jogging does not trigger the In Motion bit. This is because a jog move is not created by the master profile. If the application requires jogging, then the Jog Active bit (Axis Flags, Primary Axis Flags) should be used.
In order to monitor whether motor is moving, for both discrete and jog moves, the In Motion bit and the Jog Active bit should be used.
