Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Whats the difference between PIO-337 and PIO-347?
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
The PIO-337 is the standard CANopen bus coupler for the Parker-I/O system. A cheaper alternative is the PIO-347. The following table lists the differences between the PIO-337 "standard" and PIO-347 "econo" versions of this bus coupler.
In addition, the update rate of the PIO-347 is considerably slower than that of the PIO-337. * The PIO-347 requires the additional purchase of a PIO-602 Power Supply module
Standard Econo
Total I/O bits supported 512 32
24V Fieldside Power Supply Yes No*
No. of PDO 32 Tx / 32 Rx 5 Tx / 5 Rx
Device profile DS-401, programmable error response, marginal check, edge-triggered PDOs DS-401, programmable error response
Description No1 No2
Input current 500 mA 260mA
Standard Econo
Base Update Rate 1 ms 5 ms
Each Add'l Digital Point 15 us 100 us
Each Add'l Analog Point 40 us 270 us
