Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base GEM-VM50 screw-terminal breakout dimensions
Includes a 2-foot cable that connects into the Gemini's Drive I/O (50pin) connector.
Both dxf and pdf included:  GEM-VM50.zip
