Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Aries (AR-xxAE or AR-xxSE) Recommended Replacements
    • Aries Drive (Discontinued)-
      • Controller (CE)+
      • Drive only (AE,AR, SE, SR)+
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
Aries Replacement Options
AR-01AE or AR-01SE
PD-04P
S025V2F12I10T10M00
Motor Output
1A cont / 3A peak
3A cont / 9A peak
2.5A cont / 5.5A peak
Control Power
120/240VAC
120/240VAC
24VDC
Motor/Line Power
120/240VAC
120/240VAC
120/240VAC
Dimensions
H x W x D, mm
See below
153 x 58 x 128
169 x 38 x 172
236 x 84 x 172
AR-02AE or AR-02SE
PD-04P
S025V2F12I10T10M00
Motor Output
1.75A cont / 5.25A peak
3A cont / 9A peak
Control Power
120/240VAC
120/240VAC
24VDC
Motor/Line Power
120/240VAC
120/240VAC
120/240VAC
Dimensions
H x W x D, mm
See below
153 x 74 x 128
169 x 38 x 172
236 x 84 x 172
AR-04AE or AR-04SE
PD-04P
S025V2F12I10T10M00
Motor Output
3A cont / 9A peak
3A cont / 9A peak
Control Power
120/240VAC
120/240VAC
24VDC
Motor/Line Power
120/240VAC
120/240VAC
120/240VAC
Dimensions
H x W x D, mm
See below
178 x 74 x 128
169 x 38 x 172
236 x 84 x 172
AR-08AE or AR-08SE
PD-10P
S063V2F12I10T10M00
Motor Output
4.5A cont / 13.5A peak
6.75A cont / 20A peak
6.3A cont / 12.6A peak
Control Power
120/240VAC
240VAC
24VDC
Motor/Line Power
120/240VAC
240VAC
120/240VAC
Dimensions
H x W x D, mm
See below
178 x 83 x 128
169 x 58 x 197
236 x 100 x 172
AR-13AE or AR-13SE
PD-10P
S063V2F12I10T10M00
Motor Output
6.3A cont / 14.2A peak
Control Power
120/240VAC
240VAC
24VDC
Motor/Line Power
120/240VAC
240VAC
120/240VAC
Dimensions
H x W x D, mm
See next page
178 x 109 x 128
169 x 58 x 197
236 x 100 x 172
Aries
P Series
Compax3
Control Mode
AR-xxAE: Analog Torque/Velocity
AR-xxSE: Step & Direction TTL
Communication
RS232 (Setup only)
USB
RS232 (Setup only)
ACR9000 Cable
Yes
71-021599-xx
Analog only
Yes
71-032478-xx
Analog or Step&Dir
Yes
71-021108-xx
Analog only
Motor Power Cables
P-1A1
P-3B1
P-1A1P
P-3B1P
P-1A1
P-3B1
Encoder Cable
Incremental Encoders
F-1A1
F-4A1
F-2C1
Encoder Cable
EnDat Encoders
F-1A2
F-4A2
F-2A2
Motor Brake
Relay in drive
External Relay Required
Relay in drive
Motor Brake Power
External 24VDC
External 24VDC
Internal
Dynamic Braking
Custom
Yes
No
Braking Resistor
External
Built Into Heatsink
External
EnDat Support
Yes
Yes
Yes
SmartEncoder (Q or 3E) Support
Yes
No
Yes, w/ hall-less motor file
Retrieve absolute encoder position
Yes
Yes, click here
ACR controller? click here
No
Error Log
Yes
Yes
Yes
Position Mode Tuning
Poor
One-Click Auto Tuning
Auto Tuning
Software Oscilloscope
Basic
4channel Auto Ranging
4channel
Price*
Delivery*
days
weeks
Contact local Parker Automation Technology Center (ATC) for pricing and delivery.
The connector pinouts are different and the command cables to the drive will need to be updated.
Related FAQ:  Controller Cable Drawings
IPA Drive/Controller: Aries Controller Replacement
11/19jh
