Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Hardware - MaxPlus (MPM) Option 1 Brake Connection
The following is a table for the MaxPlus (MPM) Option 1 Brake Connection to the Compax3:
Motor Power Connections X3
Compax3 Motor Power Screw Terminals Option 1 Motor Power Cable
X3 Function Phase Pin Letter Function Wire Color
Phase U U A Phase R Red
Phase V V B Phase S Black
Phase W W C Phase T Blue
Ground PE D PE GND Green/Yellow
BRK (+) BR+ F Brake + Blue
BRK- BR- G Brake - BLUE/WHITE
***The wire colors may not apply to your cable. Option 1 cable wire colors can vary, however, the wire function should be consistent among all cables. If your cable wire marker (labels) are no longer present or readable, please contact Parker.
