Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Indexer Version - InteractX Complete Modbus Addressing Example (Modbus/RTU)
The attached InteractX project provides nearly every Modbus accessible parameter available in the P Series Indexer drive version.
P_Series_Modbus_Test_ProjetV2
glh 3/2020
