Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Misc - Profibus (I20) vs. Digital I/O (I11)
You are able to do anything you used to do with switches (via X12) also with the Profibus DP. Based on Technology (T11, T30...) you're able to do much more. The main things: enabling, homing, jogging, and absolute moves are easily available with the T11.
