Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Cables - High Flex Power and Feedback Cable Specifications
The high-flex cabling for P Series motors is designed to meet demanding flex cycle requirements.  The cables are based on ROIREV-SB cable stock from LS.  The most pertinent specifications are provided here.
Model APCS-PFxxLS APCS-EFxxES APCS-EFxxES1 APCS-BFxxQS
Description Power cable Feedback cable Feedback cable w/ battery Brake cable
Conductors 4 stranded 4 stranded pair 4 stranded pair 2 stranded
Gauge 18 AWG (0.75 mm2) 24 AWG (0.2 mm2) 24 AWG (0.2 mm2) 20 AWG (0.5 mm2)
Diameter 7 mm 6.9 mm 6.9 mm 5.9 mm
Dynamic Bend Radius 35 mm 35 mm 35 mm 30 mm
Bend Cycles 5 million 5 million 5 million 5 million
Torsion Cycles 8 million 8 million 8 million 8 million
NOTE: Feedback cables without batteries may use 3 stranded pairs instead of 4, subject to change without notice.  The outer diameter for that cable stock is 6 mm.
Full cable stock specifications are available from LS here.
Customers intending to build their own high-flex cables can use this cable stock or something similar.  Parker also offers cost-effective pre-built cables in 3 m, 5 m, 10 m and 20 m lengths.  These cables usually have very short lead times.
[Quick Link: P Series Encoder Cable Color Code and Specs]
04JUN2020 DCLIFFE
  • cable
  • feedback
  • P Series
  • encoder
  • Motor cable
