Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base MPW Motors - O-Ring seals for front of MPW Stainless Steel servo motors
Sizes in metric (mm):
MPW092   Parker 2-042  ID  82.27  W1.78
MPW115   Parker 2-047  ID 114.02  W1.78
MPW142   Parker 2-161  ID 139.37  W2.62
The MPW motors themselves have a motor shaft seal already. This O-Ring is to seal the front face of the motor. This is not included with the motor and users can source these from common seal/industrial suppliers.
For full range of material/temperature options for your application: www.parkerorings.com
