Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base DC590+ Encoder Feedback Card Options
    • DC590+ Series-
      • Why won't my motor run?
As of March 24, 2017, some of the 590+ encoder option cards were discontinued.
Specifically, AH387775U005, AH387775U012, AH387775U015, and AH387775U024 were discontinued and no longer offered.
All of these versions can be replaced by model AH387775U001.
NOTE - do not connect your encoder to the card until the voltage calibration procedure has been completed.
The -005, -012, -015, and -024 versions were simply pre-configured for a specific voltage requirement.  The -001 version is not pre-configured at the factory but supports all of the voltages the pre-configured versions supported.  Customers will need to follow a simple calibration procedure to match the required voltage.
The calibration and installation information can be obtained from this link:
HA388867 : Encoder Receiver Option - Product Manual (English)
glh  9/2020
