Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Short Circuit Current Rating (SCCR)
P-series drives, All models:
Suitable For Use On A Circuit Capable of Delivering Not More Than 5 kA rms Symmetrical Amperes, 240 Volts Maximum or equivalent.
Keywords:
PD-04P, PD-04C, PD-10P, PD-10C, PD-35P, PD-35C
fuse, breakers, UL compliance specifications installation panel cabinet
