Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base DRV Contactor Options (955+ part numbers)
  • AC/DC Industrial Drives-
    • DC590+ Series-
      • Why won't my motor run?
    • AC15/AC20+
    • DESAT (OVER I) Fault
Frame sizes 1 & 2 do not have an option call out for a contactor option.  These sizes always include an AC contactor for the in-coming AC power.  (for example - 955+8R0020)
Frame size 3 does not have a call out for a DC contactor.  If no option is specified it will always include the DC contactor for the motor armature circuit (for example - 955+8R0150)
Frame size 3 does offer an AC contactor option instead of the DC contactor.  This would be called out with the -A3 option at the end of the part number (for example - 955+8R0150-A3)
Frame size 4 has a call out for either option.  Use the call out -A4 or -D4, to specify whether an AC contactor or a DC contactor is included.  (for example - 955+8R0200-A4  or   955+8R0200-D4)
glh   Nov 2020
  • -A4
  • contactor
  • 955+
  • -D4
  • -A3
  • drv
