Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Hardware - What is the minimum regen (braking) resistor value allowed?
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
      • IPA Troubleshooting - I am able to ping my IPA but it will not connect to PMM.
Both models, the IPA04-HC and IPA15-HC require a minimum regen resistor (braking resistor) value of 22 Ohm.
How to calculate regen requirements is available here:  Regen Calculations
IPA04-HC (400W) bus capacitance is about 1680 uF
IPA15-HC (1500W) bus capacitance is about 2800 uF
glh   Nov 2020
