Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Range Error when commanding long moves - Distance limit 2^31
        • Axis Flag update rate
        • Encoder Velocity
        • Evaluation Underflow error
        • How to receive ASCII data
        • INTCAP
        • Reboot in startup program
        • Use of AXIS format
        • User Variables
        • Using Encoder 8 or 9 as SRC
        • What is the axis velocity
      • 9000 (Legacy)+
Users cannot command a single distance move that crosses 2^31 (2,147,483,648)  the rollover point.
Two potential work arounds:
You can command a JOG FWD or JOG REV (continuous moves) across that threshold and then monitor the position register.
Or, you can however get around this with commanding it as 2 different moves without stopping.
So if you wanted to do 1000 incremental move and the PPU was large (such as a motor with high resolution absolute encoder and/or with high gear ratio):
STP 0
Y/500
STP 10
Y/500
