Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Motors - P Series Motors and Cables (Specs and Additional Information)
P Series Motors  (all applicable P Series FAQ posts)
P Series Motors - Torque and Voltage Constants
P Series Motors - Shaft Load Ratings
P Series Motors - Temperature Protection
P Series Motors - Mechanical Tolerances
P Series Motors - Speed/Torque Curves 120/240vac (PM-Fxx)
P Series Motors - Brake Specifications for P Series Motors (How to Wire, Brake Delay)
P Series Motors - Pole Counts
P Series Cables - Motor Power and Encoder Cables
P Series Cables - Bend Radius
P Series Cables - Encoder Cable Color Code and Specs
P Series Cables - Multi-turn Feedback Cable Battery
P Series Cables - High Flex Power and Feedback Cable Specifications
Dynaserv Replacements
Bayside Direct Drive Rotary R100D, R150D, R200D replacements
  • PM-DDC
  • PM-DDE
  • PM-FE
  • PM-FCL
  • PM-FF
  • PM-DDB
  • PM-FAL
  • PM-FBL
  • PM-DD
