Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Motors - Pole Counts
PM-FAL = 8 poles (4 pole pairs)
PM-FBL = 8 poles (4 pole pairs)
PM-FCL = 8 poles (4 pole pairs)
PM-DDB = 20 poles (10 pole pairs)
PM-DDC = 32 poles (16 pole pairs)
PM-DDD = 32 poles (16 pole pairs)
PM-DDE = 48 poles (24 pole pairs)
PM-DDF = 64 poles (32 pole pairs)
glh Dec 2020
