Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base High Pot Option
      • High Pot Option
      • Inspection Report
      • ML18 Track Weights
      • Omega 44004 Thermistor Info
      • Phasing Diagram
      • Renishaw Optical Encoders
      • Trilogy Electrical Pitches
      • Trilogy Extension Cables
    • MX80+
    • mSR+
    • LXR+
    • mPR+
    • XE+
    • XR+
    • ZP Wedge+
High Pot Option
All IForce linear servo motors are high potential (high-pot) tested to 775 Volts phase-to-phase, and phase-to-ground.
Elevated high-pot testing of up to 1800 Volts is available as a custom option.  It is recommended that only the high-pot level needed be tested.  The higher the voltage, the more destructive the test is to the insulation of the coil.
Updated JME 11/20/12
