Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Brake Control
The P series servo drives do not include a brake relay for direct control of a motor's electromechanical brake.  Instead, an external relay is required, which can be controlled by the brake control signals (digital outputs).
See this FAQ for details on brake output wiring and drive configuration parameters.
WIRING DIAGRAMS, CONFIGURATION PARAMETERS (FOR P SERIES DRIVES)
  • PD-35P
  • PD-10P
  • PD-35C
  • PD-04P
  • PD-10C
  • PD-04C
