Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base BE Motors - MS, GS, PS & TQ Mating connector - SM & BE motors
The following table lists the MS and TQ mating cable connector information for all the SM and BE Series motors.
MS, GS*, And TQ Mating Connector Information SM16 / SM23 / BE16 / BE23 / BE34
Connector Compumotor Part Number Amphenol(Bendix) Part Number
Encoder Feedback 43-014341-01 #PT06E-14-18P(023)
Resolver Feedback 43-014341-01 #PT06E-14-18P(023)
Motor Power 43-014451-01 #PT06E-14-12S(023)
* The GS option is only available on the SM Series of motors.
Manufacturer: Amphenol Corporation, Amphenol Aerospace Division
The following table lists the PS mating cable connector information for all the SM and BE Series motors
PS Mating Connector Information SM16 / SM23 / BE16 / BE23 / BE34
Connector Compumotor Part Number* ** Intercontec Produkt GmbH Part Number
Encoder Feedback Not Available for Purchase ASTA035FR01610035000
Resolver Feedback Not Available for Purchase ASTA035FR01610035000
Motor Power Not Available for Purchase BSTA085FR23580035000
*The part numbers listed above are for crimp pin style connectors. This requires an expensive special crimping tool. Therefore, Parker has decided not to sell these connectors seperately. There is no solder cup version for the motor power connectors.
** The part numbers listed above are for crimp pin style connectors. This requires an expensive special crimping tool. Therefore, Parker has decided not to sell these connectors seperately. There is a solder cup version of the pins available under part number: ASTA035FS04610035000
Manufacturer: Intercontec Produkt GmbH
