Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base General - Connectors on Step Motor Cables?
  • Step Motors-
    • A/AX Motors - A vs M motors
    • LV/HV Motors - Customs
    • VS Motors - Motor Cables
With the S/SX systems or Zeta systems, the step motors come prewired in series with connector.
If ordering the motor only, such as ZETA57-83-MO or S57-83-MO, the motor comes with flying leads.
For S, SX and Zeta4, Zeta6104:
Part No. Description
43-008755-01 9pin Motor Power Connector
For SX8, ZETA8, ZETA6108, ZETA12, ZETA6112:
43-013575-01 7pin Motor Power Connector
For all other step motors, no connector is provided on the end of the flying leads or cable. The connector is provided with the drive.
For systems with the motor wired in parallel, these are available as a custom product. For other motors to be purchased as part of a system, these can also be done as a custom product. You may contact your local Parker ATC for these requests.
