Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Standard resolver in MPM and MPP series motors
When considering use of a third party drive and the MPM or MPP series motor, the main things to consider for compatibility of the drive with the resolver are the input voltage, the transformation ratio and the operating frequency/excitation.
The input voltage for the standard resolver is 4 Volts running at a frequency or excitation of 4 kHz. The main item is the transformation ratio, which needs to be 0.5.
