Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Troubleshooting - C3ServoManager - Error Trying to Launch Codesys: "The parameter is not correct."
If every time you click on CoDeSys from C3manager you get a pop-up that says "The parameter is not correct.", then your CoDeSys files are located in the wrong folder on your computer. Move all project files to your CoDeSys/Projects directory, for example:
C:\Program Files\3S Software\CoDeSys V2.3\Projects
