Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Hardware - Short Circuit Current Rating (SCCR)
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
IPA series, all models:
Short Circuit :            5000A / 240VAC, 1-Phase
Suitable For Use On A Circuit Capable of Delivering Not More Than 5 kA rms Symmetrical Amperes, 240 Volts Maximum or equivalent.
Keywords:
IPA04-HC, IPA15-HC
fuse, breakers, UL compliance specifications installation panel cabinet
