Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Parker Remote Browser -- Connect to Xpress HMI at Startup
    • Interact (Legacy)+
    • Interact Xpress-
    • IX / PCA+
Some users of Parker Remote Browser may want to have it connect directly to a specific Xpress HMI when they open it.  There is not an option to change the home page in Parker Remote Browser, but command line arguments can be used to perform this task.  The Command Prompt command to do this is shown below.
"C:\Program Files\Parker Remote Browser\Parker Remote Browser\Parker Remote Browser" -url 192.168.100.150
The IP address after the "-url" flag should be modified to match the IP address of the Xpress HMI.  This command can be saved in a Batch file (extension ".bat") for easier use.  Please note that the command shown above assumes Parker Remote Browser is installed in the default installation directory.
12MAR2021 DCLIFFE
  • Xpress
  • browser
  • home page
  • Remote
