Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 598/599+ Stack Controller Replacements
    • DC590+ Series-
      • Why won't my motor run?
European models listed can be replaced directly with the US model numbers listed.
European                                                     US Equivalent
598P-53260010-TP00-U4V0      598+99999
598P-73260010-AP00-U4V0     598+99999/A/690
598P-73260010-TP00-U4V0     598+99999/690
599P-53260010-TP00-U4V0     599+99999
599P-53260010-TP00-U4A0   (discontinued - use 599+99999)
If your 598 / 599  model or catalog number differs from any shown here, contact our Applications Department to evaluate and make a recommendation for replacement.
glh    May 2021
